Lathe cutoff tool
Lathe cutoff tool
I just got a lathe cutoff tool that uses replaceable carbide inserts. What a difference after using HSS blades.
Mr.Ron from South Mississippi
Re: Lathe cutoff tool
I use Iscar and Kennametal parting tips, have not parted with a HSS parting blade for 20 years except for plastics.
Most of the carbide tips have a V shape cut into them that will fold the chip from both sides inwards, making it less likely the chip will jam in the cut.
The only problem with the vee shaped inserts is they cut off the piece, but leave a "tit" on the cut off piece that has to be removed by other means; (by filing/grinding, etc).
That depends on the insert. As I recall, you can get them with a left, right, or center bias. The ones I have for my Sandvik blade leave the tit on the material, not the drop/part.
I prefer it that way, as I won't have to re-chuck the part to remove it. If you keep running the cutoff tool , it will take the tit off the part in the chuck.
I'm looking for a blade insert holder to use in a rear-mounted parting toolpost (which I've built.)
An insert holder which gets raves by ME/HSMs in England is a Sandvik QD item. Although the particular QD holder they list is mounted for use in indexing toolposts, they have apparently concocted a combination of holder and insert which perfectly matches ME/HSM range of work. The seller (Greenwood Tools) equips their holder with a "Type 18, Grade GC1125" insert, but considering the bewildering numbers of insert types, common sense tells me that "18" isn't enough numbers to identify the insert.
Anyway, any information or experiences you have along those lines would be helpful. And yes the parting tool would be inverted.
GWRdriver
Nashville TN
Nashville TN
I've been happy with the mgmn partying tool that I bought a few months back. Way better than hss for speed. I am using the 2 mm wide version.
Still looking for a 1mm version of same..
If you continue feeding the tool forward, it will remove the tit from the chucked piece as well.
