I have an old Myers well pump that I wish to cleanup and paint. I want to blast it to remove some old paint and a bit of rust, and I wondered what media would work best.
Thanks.
Blasting cast iron
- neanderman
Blasting cast iron
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Re: Blasting cast iron
I like the course silica sand for that, but you have to have the right PPE to protect you from the dust.
Sent from my SM-N976U using Tapatalk
I have done some blasting of paint off various cast iron and cast steel (bits of transmissions and engines) and used aluminum oxide grit. It digs deep into the existing paint and produces a fine scuff pattern on the material that the new paint readily locks onto. But you want to protect gasket surfaces unless you intend to resurface them.
- neanderman
Thanks, gentlemen! No gasket surfaces are involved.
Ed
Atlas 618
Atlas 618
