Hey, Lou,
Edit your profile and put in your location.
Maybe someone can go in with you on a gallon.
Is this any good for way oil?
Re: Is this any good for way oil?
Looks,like what you bought is commonly used in newer model automobiles - for modern transmissions. key words on the label of the bottle are “extreme pressure” lubricant. This means the oil contains EP additives that can have a corrosive effect on bearing surfaces - called “polishing wear”. This causes excessive tooth wear on gears for example.
See the link below for more good stuff on EP oils.
https://www.machinerylubrication.com/Re ... -additives
maybe, maybe, mix small quantities in your cutting oil to use it up. Otherwise, write off the .25Cents and throw the oil away in the local toxic recycle dump... :]
- liveaboard
My comment was intended for Armscor1, who wrote that he can't get those products in the Philippines.BigDumbDinosaur wrote: ↑Thu Sep 17, 2020 11:05 am For most recent vintage machine tools, Vactra #2 or similar for horizontal slideways and Vactra #4 or similar for vertical slideways works well.
Here in Portugal, when I asked about slideway oils they looked at me like I was speaking a foreign language [which of course, I was].
I bought by mail order from the UK.
