Special Die
warmstrong1955
Re: Special Die
Post by warmstrong1955 »
SteveM wrote: Mon Jul 27, 2020 8:50 pm
warmstrong1955 wrote: Mon Jul 27, 2020 7:07 pm I have a 1/4-32 tap. It's what a lot of oilers are.
Why they made grease zerks in 1/4-28, but oilers are 1/4-32....I have no clue.
So that nobody would mix them up.
Same reason different gasses have different threads, even left hand vs right.
Sure.....why not? Good a reason as any! I know people that can't tell an oiler from a zerk.
(I'm stickin' with the opium thing)
Bill
liveaboard
Re: Special Die
Post by liveaboard »
I get grease zerks in all sorts of different threads; 6mm x 1mm tapered [only time I've seen a tapered metric thread] is most common on this side, I buy them by the dozen.
npt 1/4", 1/8" too.
But never seen 1/4- 28.
I've often wondered about those schrader valve threads, so thanks for another bit of useless trivia no one I ever meet will ever care about!
I've learned to just keep quiet about my thoughts...
warmstrong1955
Re: Special Die
1/4"-28 is very popular in automotive parts, over here anyway.
The Schrader thread sizes became very important, when buggered up valve core threads became the difference between a million dollar piece of equipment running.....or not.
Sometimes, you never know what you might need to know, and have!
Re: Special Die
Post by Bill Shields »
don't get me started on taps and dies for old sewing machines....everyone used different sizes to that you HAD to purchase parts from THEM.
many were even left handed for no other reason than to force the owner to 'phone home' for exact replacement parts.
Rich_Carlstedt
Re: Special Die
Post by Rich_Carlstedt »
Russ Hanscom wrote: Sun Jul 26, 2020 12:37 pm Has anyone run across a 19/64"-32 die? (aka .2969"-32) .................................................. Plan A is to see if a 5/16-32 in a Geometric head will collapse enough. ..................................................................
Not a problem , I do that all the time with my Geometric head
You can go about .062 Plus or Minus from the Die set size.
So a 5/16 die should work fine
Rich
As a side note. write down where you have those indexing marks and keep it with the Geo head
so next time you don't need to hunt for the right setting
Rich
Russ Hanscom
Re: Special Die
Post by Russ Hanscom »
Thanks, I thought it might.
Rich_Carlstedt
Re: Special Die
A note to those not familiar with Geometric heads.
These Die heads were greatly used by Screw Machines years ago, but when CNC lathes and machines took over,
They became obsolete. They have Die inserts ( threaded cut edges) that can be resharpened and in order to allow that, the heads
are adjustable for thread size as a resharpened edge would cut an oversize thread without this adjustment.
This can be of great use when you do not have all the different size dies, so you can use the thread count
So your 1/4-28 die can also cut a 5/16-28 thread or a 12-28 for example
Rich
liveaboard
Re: Special Die
Thanks for that, I was wondering what it was but was too embarrassed to ask!
GlennW
Re: Special Die
Post by GlennW »
All about the Geometric Die Heads.
https://www.youtube.com/watch?v=eMUrpTcoOlY
Re: Special Die
Thanks, Glenn. Great link!
