Duburring Raw Stock
Duburring Raw Stock
Just received an order from a metal supply company. Some (newbie) observations:
1. Shipping took far longer than the junk my wife orders from QVC and the like. Part of this was it took almost a week to process the order internally and ship (at least judging from the email confirmations I received). Perhaps they are understaffed due to Covid precautions.
2. The order was exactly what I ordered (good). but they had neglected to deburr the stock. Sharp enough to cut your fingers had I not been careful unwrapping it. Do you think this is just a cost avoidance measure, or is there some legitimate reason some customers do not want stock deburred?
3. I noticed the deburr tool worked quite well in on direction, but not worth a hoot in the other. Careful inspection revealed the deburr blade is not symmetric (as I had assumed) and definitely has a cutting side and a non-cutting side.
Learn something new every day...
Kelly Jones, PE
George Bernard Shaw
(1856-1950)
George Bernard Shaw
(1856-1950)
Re: Duburring Raw Stock
Generally, deburring blades for steel are asymmetrical to cut properly. Unidirectional.
Blades for brass, cooper alloys and plastics are symmetrical. Bidirectional.
And I've seldom received stock materials that have been deburred.
Most stock I have gotten from metal suppliers has not been deburred.
After a few painful lessons, whenever I make a cut, I deburr both pieces; the one I am going to use and the one I put back on the rack - it really saves a lot of blood shed!
RussH reminded me that my habit is also to deburr any metal stock I'm using before it hits the storage racks.
Sounds normal to me.KellyJones wrote: ↑Mon Jul 20, 2020 5:14 pm Just received an order from a metal supply company. Some (newbie) observations:
Also sounds normal to me. Deburring is labor that would add to the cost, which most customers avoid. It's no different than ordering random lengths from a steel house.2. The order was exactly what I ordered (good). but they had neglected to deburr the stock. Sharp enough to cut your fingers had I not been careful unwrapping it. Do you think this is just a cost avoidance measure, or is there some legitimate reason some customers do not want stock deburred?
You should always assume you are getting material that has not been deburred when you unwrap it. I wear leather-palmed gloves when I unbundle material.
Agreed. I buy a lot of "structural steel" for my projects. When I don't get full 20' lengths, they cut it to the length I need using a really big chop saw. It produces an insane razor burr, and there is no discussion or expectation that they would address that. Even if they did, it's unlikely they would deburr in exactly the manner I would want, so it's really extra cost for no benefit. The end is also not necessarily as square as I would like (assuming I even want it square), so as long as the burr can be oriented such that it doesn't interfere with a squaring cut, then it's going in the scrap/trash anyway.
The steel supplier I deal with will not debur anything as too many customers wanted it deburred "their" way,
Sheech! It's "raw material". Do you expect the steaks from the butcher to be already grilled?
...lew...
...lew...
- tornitore45
Is a good practice I learned to do myself. Also every time a part change orientation in the mill vise need to be deburred to guarantee it sits square and clamp solid. So there it goes the belt sander or the three corners scraper.After a few painful lessons, whenever I make a cut, I deburr both pieces; the one I am going to use and the one I put back on the rack - it really saves a lot of blood shed!
Or as I've shared before, a Deburring Wheel.
Probably the most frequently used power tool in my shop.
> direction
Shaviv has both right and left hand scraper blades. The other companies probably to as well.
- liveaboard
My system is simple; I just keep a roll of duct tape in the workbench top drawer.
Just tape up those sliced fingers instead of wasting precious time deburring.
