I need to empty a sandblasting pressure pot, containing 50kg of grit, is not practical to tip upside down. I asked on Chaski and was suggested to use a vacuum/blow gun, I'm in UK, got a Lidl Parkside version. also bought a large 25 litre bucket to put the grit in. I can use the hose on my mitre saw, to connect the gun via the hose to the bucket. Propose using holesaw on lid of bucket, then superglue hose adapter in place, then crimp hose to adapter. Will need to fit another adapter in lid for guns dust bag, to allow compressed air out of bucket.The mitre saw hose has an internal diameter of 30mm. Need a hose adapter something like in screenshot. I can't find an adapter with an OD of say 28mm. I've seen air fittings, that have a barrel and washers on each end to fit into wall of sandblasting cabinet. A plastic hose adapter like that would be better, could dispense with buying the superglue.
Perhaps I'm not using correct Google search term for hose adapters and is reason don't seem to be able to find a suitable adapter, or using fittings in combination to cobble up something joining hose, adaper and lid.
Anyone, any ideas?
Ta:)
Dust Extraction Hose Fitting
Re: Dust Extraction Hose Fitting
Not to worry, got it all sorted out now.
