I'm finally getting back to finishing my G8 project, and would like to try to find a manual for it. Google served up a few sales brochures, but no manual. I've managed to figure out most of what I need to know for it, but would love to have a manual just for general reference.
One thing I haven't figured out is the "wet" system. There is a sort of mister bar under the table that sprays the grit side of the belt as it goes below the table. But I don't see any provision for accumulation of excess coolant. I haven't tried to activate the system yet, but the design seems to imply a very light mist system that operates as a "total loss". Presumably excess coolant along with debris are to be extracted from the bottom collector port? Since I don't have a massive collector system, that could prove problematic. If I use it, and I'm not missing something, I expect that means I'll just have to put in a catch basin of some sort for it to gravity drain into.
Looking for a Porter Cable G8 owner manual
Re: Looking for a Porter Cable G8 owner manual
You've probably already found this sales material:
http://vintagemachinery.org/pubs/650/21908.pdf
There are several people on vintagemachinery.org that have the machine.
http://vintagemachinery.org/mfgindex/de ... =650&tab=4
Try contacting some of them to see if they have the manual.
For those that want to know what it is, here's a picture: Steve
