Just ran across this beast while going a google search for something else.
Looks like someone took a radial arm drill base and table, mounted a lathe headstock and a mill overarm to it and called it "Labormil".
http://www.lathes.co.uk/labormil/
It's a full lathe with change gears and the table can both be a toolholder and a workholder.
Interesting mechanism to keep the change gears engaged as the machine is raised and lowered.
If a lathe, horizontal mill and a radial arm drill had a baby
Re: If a lathe, horizontal mill and a radial arm drill had a baby
The triangular gib is also an interesting and elegant mechanism.
Same design committee that turned the horse into the giraffe?
--earlgo
--earlgo
