loose screw issue
Re: loose screw issue
Use a coin slot in the thumb screw instead of wings.
That's a good idea shoo the other route, I'd like to try to stick with the format I use now though if I could as I already have about 128 pre turned thumb screws
Thanks Bill,warmstrong1955 wrote: ↑Mon Apr 27, 2020 9:24 am Also, have you ever used V-3? It’s similar to Loctite, but works more like a patch or nylon insert screw.
Spray it on, let it dry, and assemble. You can still adjust it, but it increases the friction to do so, and will last a while.
Bill
That sounds like it will work for short term use. The thing is this needs to be able to be unscrewed often as the guys like to clean their reels and must last for many many years.
Good idea, and it's used currently by another manufacturer. The issue with it is it's a little too generic looking and looks cheap. My customers would lose a nut if I ever put one on
John Hasler's idea of a nylock insert seems to be the best idea as far as ease of application and adaptability to my existing thumb screw. I just did a test with one and bored a .0625" hole in the side and machined a piece of nylon the correct dia. To my surprise it works awesome! Even if it's unscrewed and inserted many times. I have more testing to do but I think that's the ticket, so thanks John!
And thanks to everyone that offered ideas, that's very much appreciated and why I come here. Since I already have all the screws made I will finish this project with the thread lock insert shown above but moving forward if anyone still has any other ideas outside the box, such as a complete overhaul of the spool containment mechanism I'm all ears.
Wavy washers, might work.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
Thanks Patio, I've considered those including curved spring washers but they have a tendency to fall off if someone isn't paying attention when they take it apart. I have to think of everything to mitigate issues down the road like that.
Mebbe a washer that has a flexible dog like on a perscription bottle child proof cap. Goes under the knob, which has a couple of indents in it for the catch to grab.
Scotty
Scotty
I wouldn't think that any adhesive at all would be needed but a bit of cyanoacrylate might help.
One thing to keep in mind with nylon locking devices is that they have a limited life, wearing out, and don't hold anymore. On aircraft I was taught to toss nylock nuts after 3 times on and off. Sometimes hard to know how often a nut was used so wouldn't use them if they felt too easy to put on. Are your customers going to be able to replace the thread lock insert themselves at home or stream side?
Pete
Pete
From what I understand the screws will still work even after the nylon is worn out (if it does wear out): they will just have a slight tendency to work loose. Thus the user can put it back in at streamside and then if she later notices that it is working loose order a replacement screw.
