Bandsaw Blades
Bandsaw Blades
For years I have heard the experts remind us newbies and hobbyists to verify the teeth of a newly installed bandsaw blade be pointing the right direction. I dutifully checked each time, but for the life of me I couldn't see how one could end up with the teeth pointing the wrong direction. Then it happened to me the other day.
I had trouble uncoiling a new blade the other day and it turns out that it is possible to turn the blade "inside out" when uncoiling. That had not occurred to me before, and the result was teeth pointing the wrong way.
I also found put it increases the risk of kinking the blade significantly. And a kinked blade will throw teeth. Expensive lesson, but I think I learned it well.
Kelly Jones, PE
A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing.
George Bernard Shaw
(1856-1950)
George Bernard Shaw
(1856-1950)
Re: Bandsaw Blades
Yep! It's all too easy to get a blade on backwards, especially if one welds their own. Easy enough to turn them inside out to make a correction, but one must be aware that it's possible.
Re: Bandsaw Blades
What I want to know is why in the last 20 years has every, and I mean every blade I have purchased for my Marvel saw has uncoiled backwards????
Nyle
Nyle
Re: Bandsaw Blades
Perhaps your saw is backwards?
Re: Bandsaw Blades
I got a blade welded at a blade shop and the teeth were backwards. When I complained they told me just to turn it inside out. Who knew? Just be sure to wear gloves.
Jack.
Jack.
- tornitore45
Re: Bandsaw Blades
Where you born in the Southern Hemisphere?What I want to know is why in the last 20 years has every, and I mean every blade I have purchased for my Marvel saw has uncoiled backwards????
Mauro Gaetano
in Austin TX
in Austin TX
Re: Bandsaw Blades
Born in the North, maybe I need to move south, or hang upside down....go figure!
Re: Bandsaw Blades
You just need to turn your bandsaw inside-out.
Re: Bandsaw Blades
If I do that then the blades will uncoil in the opposite direction....I'm doomed!
Re: Bandsaw Blades
What I need is a bimetal crosscut saw blade that cuts in either direction.....yeah, that's the ticket.
- warmstrong1955
Re: Bandsaw Blades
Would that be considered cutbidextrous?LIALLEGHENY wrote: ↑Sat Apr 25, 2020 6:54 pm What I need is a bimetal crosscut saw blade that cuts in either direction.....yeah, that's the ticket.
