Bandsaw Blades
KellyJones
Bandsaw Blades
Post by KellyJones » Fri Apr 24, 2020 12:37 pm
For years I have heard the experts remind us newbies and hobbyists to verify the teeth of a newly installed bandsaw blade be pointing the right direction. I dutifully checked each time, but for the life of me I couldn't see how one could end up with the teeth pointing the wrong direction. Then it happened to me the other day.
I had trouble uncoiling a new blade the other day and it turns out that it is possible to turn the blade "inside out" when uncoiling. That had not occurred to me before, and the result was teeth pointing the wrong way.
I also found put it increases the risk of kinking the blade significantly. And a kinked blade will throw teeth. Expensive lesson, but I think I learned it well.
Kelly Jones, PE
A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing.
George Bernard Shaw
(1856-1950)
Re: Bandsaw Blades
Post by Harold_V » Fri Apr 24, 2020 4:00 pm
Yep! It's all too easy to get a blade on backwards, especially if one welds their own. Easy enough to turn them inside out to make a correction, but one must be aware that it's possible.
LIALLEGHENY
Re: Bandsaw Blades
Post by LIALLEGHENY » Sat Apr 25, 2020 6:00 am
What I want to know is why in the last 20 years has every, and I mean every blade I have purchased for my Marvel saw has uncoiled backwards????
Nyle
John Hasler
Re: Bandsaw Blades
Post by John Hasler » Sat Apr 25, 2020 7:02 am
Perhaps your saw is backwards?
JackF
Re: Bandsaw Blades
Post by JackF » Sat Apr 25, 2020 11:13 am
I got a blade welded at a blade shop and the teeth were backwards. :( When I complained they told me just to turn it inside out. Who knew? :roll: :wink: Just be sure to wear gloves. :wink: :)
Jack.
tornitore45
Re: Bandsaw Blades
Post by tornitore45 » Sat Apr 25, 2020 1:22 pm
Where you born in the Southern Hemisphere? :lol: :lol:
Mauro Gaetano
in Austin TX
whateg0
Re: Bandsaw Blades
Post by whateg0 » Sat Apr 25, 2020 4:27 pm
Jack.
And hold it away from your face!
Dave
LIALLEGHENY
Re: Bandsaw Blades
Post by LIALLEGHENY » Sat Apr 25, 2020 5:53 pm
Born in the North, maybe I need to move south, or hang upside down....go figure!
John Hasler
Re: Bandsaw Blades
Post by John Hasler » Sat Apr 25, 2020 6:40 pm
You just need to turn your bandsaw inside-out.
LIALLEGHENY
Re: Bandsaw Blades
Post by LIALLEGHENY » Sat Apr 25, 2020 6:47 pm
If I do that then the blades will uncoil in the opposite direction....I'm doomed!
LIALLEGHENY
Re: Bandsaw Blades
Post by LIALLEGHENY » Sat Apr 25, 2020 6:54 pm
What I need is a bimetal crosscut saw blade that cuts in either direction.....yeah, that's the ticket.
warmstrong1955
Re: Bandsaw Blades
Post by warmstrong1955 » Sat Apr 25, 2020 7:02 pm
Would that be considered cutbidextrous?
