Bandsaw Blades
KellyJones
Bandsaw Blades
Post by KellyJones »
For years I have heard the experts remind us newbies and hobbyists to verify the teeth of a newly installed bandsaw blade be pointing the right direction. I dutifully checked each time, but for the life of me I couldn't see how one could end up with the teeth pointing the wrong direction. Then it happened to me the other day.
I had trouble uncoiling a new blade the other day and it turns out that it is possible to turn the blade "inside out" when uncoiling. That had not occurred to me before, and the result was teeth pointing the wrong way.
I also found put it increases the risk of kinking the blade significantly. And a kinked blade will throw teeth. Expensive lesson, but I think I learned it well.
Kelly Jones, PE
George Bernard Shaw
(1856-1950)
Re: Bandsaw Blades
Yep! It's all too easy to get a blade on backwards, especially if one welds their own. Easy enough to turn them inside out to make a correction, but one must be aware that it's possible.
LIALLEGHENY
Re: Bandsaw Blades
Post by LIALLEGHENY »
What I want to know is why in the last 20 years has every, and I mean every blade I have purchased for my Marvel saw has uncoiled backwards????
Nyle
Re: Bandsaw Blades
Post by John Hasler »
Perhaps your saw is backwards?
JackF
Re: Bandsaw Blades
Post by JackF »
I got a blade welded at a blade shop and the teeth were backwards. :( When I complained they told me just to turn it inside out. Who knew? :roll: :wink: Just be sure to wear gloves. :wink: :)
Jack.
tornitore45
Re: Bandsaw Blades
Post by tornitore45 »
Where you born in the Southern Hemisphere? :lol: :lol:
whateg0
Re: Bandsaw Blades
Post by whateg0 »
JackF wrote: Sat Apr 25, 2020 11:13 am I got a blade welded at a blade shop and the teeth were backwards. :( When I complained they told me just to turn it inside out. Who knew? :roll: :wink: Just be sure to wear gloves. :wink: :)
Jack.
And hold it away from your face!
Dave
LIALLEGHENY
Re: Bandsaw Blades
Born in the North, maybe I need to move south, or hang upside down....go figure!
Re: Bandsaw Blades
You just need to turn your bandsaw inside-out.
LIALLEGHENY
Re: Bandsaw Blades
If I do that then the blades will uncoil in the opposite direction....I'm doomed!
LIALLEGHENY
Re: Bandsaw Blades
What I need is a bimetal crosscut saw blade that cuts in either direction.....yeah, that's the ticket.
warmstrong1955
Re: Bandsaw Blades
Post by warmstrong1955 »
LIALLEGHENY wrote: Sat Apr 25, 2020 6:54 pm What I need is a bimetal crosscut saw blade that cuts in either direction.....yeah, that's the ticket.
Would that be considered cutbidextrous?
