123 blocks Dumb Question
I have a Millrite, 8x36" with 5" vise. I recently purchased. I am a newbee but not a total idiot but you be the judge. I'm gathering tooling. My question: Do 123 blocks come in 1/2" holes? I would think one would at times want to secure block to the table. My table has 5/8" slots and use 1/2"-13 stud bolts but most blocks i've seen have 3/8" holes therefore am I required to make T nuts to fit a 3/8" stud bolt that fits the table slot I have. Is this a dumb thing to be asking as blocks are not used in this way? I am thinking of buying some to elevate the work piece so perimeter cuts can be made on thin pieces larger than the what the vise will hold. If I can run a stud bolt through the work piece then through the block and secure it to the T nut to secure without the need to move clamps.
Re: 123 blocks Dumb Question
purchase a set of blocks and bore out holes as needed
The blocks are no hardened ??
They are typically harder than the hinges of hell, so boring them would be quite challenging.
Use your mill to make new T-nuts with 3/8" tapped holes.
I put a carbide end mill through two holes in a set in a couple of hours. Granted they are cheapie blocks..but they serve the intended purpose...to lift a rotary table so that the handle clears the mill table.
- tornitore45
1-2-3 block are supposed to have some 3/8 threaded holes and some clearance holes for a 3/8 stud.
At some point in the history of transferring our industrial capability to China, were all sort of product are copied and cheapened, some knucklehead (here in the US or in China) made the mistake to drill all holes for tapping 3/8-16 and forgot or cost reduced the operation to open up the other holes to clearance hole for a 3/8 stud.
Nowadays a properly made block is a rare find.
After ruining some $80 in carbide end mills, carbide ball end mill, and carbide drill I finally bored the suckers by destroying 3 masonry bits.
It was not pretty but at that point it was a matter of principle. Me or the Blocks.
my blocks must be softer than yours (admittedly from a cheap asian supplier)...
carbide end mills went right through the holes...
or my carbide end mills are better than yours giggle....
- tornitore45
Being somewhat tight, that is not hard to believe.or my carbide end mills are better than yours giggle....
nah....mine are as cheap as they come made on this side of the pacific
- tornitore45
McMaster sells 3/8-16 T-slot nuts sized for 5/8 slots.
but, as someone already said- you can make them yourself.
