I have a phase converter I built years ago, works fine. (it has an idler motor) I picked up a phase-o-matic phase converter and I am going to hook an idler motor up to it(better efficiency) for use in another another building. Both converters will be hooked up with plugs so they will be interchangeable. (input and output have plugs/recepticles)
I understand if the motor you are powering has a reverse rotation, you reverse a pair of the 3 phase wiring to get the forward motion. My question is... If the single phase L1 and L2 input to the phase converter wiring is reversed will the 3 phase change direction also??? I am trying to make these so they are interchangeable if one were to fail I can swap them without a hassle. Crickets.... haha
Phase converter theory question.
Re: Phase converter theory question.
My uneducated guess is that swapping the input will not have any effect. The idler will still rotate in the same direction and the phase relationship between the single-phase input and the idler will remain the same.
I was thinking the same... The idler rotation is based on the way the jump start capacitor is hooked to it. The idler rotation is what determines the 3 phases.ChipMaker4130 wrote: ↑Sun Sep 29, 2019 11:06 am My uneducated guess is that swapping the input will not have any effect. The idler will still rotate in the same direction and the phase relationship between the single-phase input and the idler will remain the same.
B Mann writes:
No.
No.
