Monster Collett
armscor 1
Monster Collett
Post by armscor 1 »
Bit big for my mill!!
Slots cut with EDM.
jcfx
Re: Monster Collett
Post by jcfx »
First thing that came to mind was it's make a really expensive waste basket !
That is one SERIOUSLY sized collet, is it a ER 600 ? ;)
Inspector
Re: Monster Collett
Post by Inspector »
It isn't the collet that is big, it's the calliper that is miniature. ;)
Pete
armscor 1
Re: Monster Collett
Post by armscor 1 »
Spot on, 600mm diameter, made in UK.
Re: Monster Collett
Post by spro »
I think you need harbor that and treat it like gold.
Re: Monster Collett
Post by SteveM »
I can't even fathom how big the machine is.
jcfx
Re: Monster Collett
Post by jcfx »
SteveM wrote: Tue Sep 10, 2019 9:07 pm I can't even fathom how big the machine is.
I'm not even sure if it's a work holding or tool holding ( both ? ) collet,
the big question is ( pun intended ) what's the collet nut and wrench look like !
pete
Re: Monster Collett
Post by pete »
If I had to guess it's probably not for a machine tool at all. Used as a quick attach / removal on fairly high maintenance precision shaft drive maybe?
Cary Stewart
Re: Monster Collett
Post by Cary Stewart »
Note that none of the slots go thru to the bottom alternately like the ER series. This is probably not a collet.
Cary
Re: Monster Collett
Not all collets are slotted from both ends. In fact, most are not. I offer you the two most common, the R8 and the 5C, both of which are single taper collets. Collets that are slotted from each end are double taper collets, of necessity.
The collet shown appears to be a single taper.
