Monster Collett
Re: Monster Collett
First thing that came to mind was it's make a really expensive waste basket !
That is one SERIOUSLY sized collet, is it a ER 600 ?
Re: Monster Collett
It isn't the collet that is big, it's the calliper that is miniature.
Pete
Pete
Re: Monster Collett
Spot on, 600mm diameter, made in UK.
Re: Monster Collett
I think you need harbor that and treat it like gold.
Re: Monster Collett
I can't even fathom how big the machine is.
Re: Monster Collett
If I had to guess it's probably not for a machine tool at all. Used as a quick attach / removal on fairly high maintenance precision shaft drive maybe?
Re: Monster Collett
Note that none of the slots go thru to the bottom alternately like the ER series. This is probably not a collet.
Cary
Cary
Re: Monster Collett
Not all collets are slotted from both ends. In fact, most are not. I offer you the two most common, the R8 and the 5C, both of which are single taper collets. Collets that are slotted from each end are double taper collets, of necessity.
The collet shown appears to be a single taper.
