What is a good rust preventative for machine storage.
Re: What is a good rust preventative for machine storage.
Hi There,
Please, no Jabberwockies. Rabbits are okay.
Good Luck!
-Blue Chips-
Webb
Good Luck!
-Blue Chips-
Webb
- SteveHGraham
I got myself some lanolin and a spray bottle. Now I need a solvent. I am waffling between kerosene and mineral spirits. Which will do the least damage to paint?
I was planning on boiling some ATF, bit of kero, and bee wax - use a pump up garden sprayer...
- SteveHGraham
I am Googling around, and people are saying mineral spirits will only damage fresh paint, whereas kerosene may be more problematic.
- SteveHGraham
Think maybe I'll add a touch of motor oil; lanolin all by itself is waxy.
- SteveHGraham
I got myself a pound of lanolin from Ebay, supposedly. Turned out to be more like 15 ounces, so I am waiting for the seller to respond to a complaint. I bought mineral spirits today, and tonight I worked on mixing them.
The lanolin does not like to dissolve in room temperature mineral spirits. I put maybe 20 ounces in a saucepan and heated it to the temperature of hot bath water. The lanolin came in a plastic bag, and I could not figure out how to get all of it out, so I cut the bag open and put it in the pan. The lanolin came loose, and I was able to get virtually all of it into the mineral spirits. I did not add oil.
When it had dissolved, I used a funnel to pour it into the mineral spirits can, and that was that. I have a solution that is somewhere around 15% lanolin by weight. I poured a spray bottle full of it, so now I have a quart ready to apply.
Comes out to around $8.50 per quart, including the cost of the bottle. Cheaper, if I get the lanolin seller to refund me $1.50 for the missing ounce.
This weekend I'll shoot some of it onto some metal and see how it looks.
Hi Steve,
I found a bottle of liquid lanolin on line. Haven’t tried it yet, but might be an option if the solid lanolin doesn’t work out.
What did your kitchen smell like when you were done?
- seal killer
All--
For those of us with shops on HVAC, I agree with atunguyd, a dehumidifier works exceedingly well. I have always used one in both the shop and the gun room. I've got one running right now down in the vault. I'm not sure I need it, but it keeps me happy knowing that stuff is dry.
My machinery is STILL in a temperature/humidity controlled environment. Maybe not much longer, though. The house is almost finished. Then I'll start on the shop.
--Bill
--Bill
You are what you write.
Dehumidifier? What's that? I've heard it's often related to something else I heard was called rust. I've seen it in pictures, but I have no frame of reference to understand what that is. Is that something I will have to worry about when I move in with you Bill?seal killer wrote: ↑Sat Nov 10, 2018 2:41 pma dehumidifier works exceedingly well. I have always used one in both the shop and the gun room. I've got one running right now down in the vault. I'm not sure I need it, but it keeps me happy knowing that stuff is dry.
