Surface Grinding
Re: Surface Grinding
Post by GlennW »
You're all set!
ctwo
Post by ctwo »
So far I've made mostly very sharp edges, but discovered a large melty burr on the trailing edge. Otherwise just taking it slow.
Even the roughing passes are staying within two hundred millionths on either side. I will need to configure a squareness comparator. I know how to use the surface gauge with the ball on the end of the mounting mast.
Post by GlennW »
ctwo wrote: Fri May 20, 2022 3:51 pmSo far I've made mostly very sharp edges
https://www.amazon.com/EZE-LAP-PAK-Colo ... 1618&psc=1
They do a great job of breaking sharp corners.
A stone works well too, but these stay flat if you use them on a corner. (and don't break when you drop them)
I've had a Fine EZ Lap for years that I also use for tuning up HSS and carbide cutters. Can't wear it out!
Carrdo
Post by Carrdo »
Also, don't forget to use a precision ground flat stone on the mag chuck top surface regularly to remove any raised burrs or dings and micro scratches which will almost certainly build up, with time, as you place and remove workpieces from the mag chuck. I am talking about precision ground toolroom stones not the regular ones. One can google precision ground toolroom stones or precision ground flat stones as several vendors offer them for sale.
ctwo
Post by ctwo »
This v-block is becoming my favorite one. Only these two holes left.
Post by GlennW »
Grinding is quite a rewarding process when all goes well.
ctwo
Post by ctwo »
GlennW wrote: Fri May 20, 2022 5:10 pmI've had a Fine EZ Lap for years that I also use for tuning up HSS and carbide cutters. Can't wear it out!
I was remembering it as "20" years and that made me sad thinking of all that lost joy I could have had. These look marvelouse! :mrgreen:
earlgo
Post by earlgo »
Back to holding parts on the grinder, here is another way to hold small parts. I made this 1" wide by 2_3/4" long vise several years ago. The moveable jaw is 3/8 thick and the vise body is 3/4" thick. It came in very handy for this small part by placing it on a small magnetic block.
small vise
small vise
The mag block is from Titan Tool and when turned on, holds itself to the grinder table as well as holding on to whatever is on top. (The vise is against the end stop.)
--earlgo
ctwo
Post by ctwo »
How did you create the surface pattern on the vise?
I cheaped out a while back and bought two 1" screwless vises.
earlgo
Post by earlgo »
Re: the pattern. At the Colorado School of Trades, we used small wire cup brushes loaded with valve grinding compound to jewel rifle bolts because the wires would spring and follow the curved surface.
For this I used a flat ended abrasive cylinder that is held in a collet chuck that is spun vertically in a drill press. It need not be spun too fast. It is in the center pocket of the box in the attached photo.
The pattern created is up to you.
These abrasives are great for use in a Dremel tool to polish small parts.
--earlgo
earlgo
Post by earlgo »
I got a little carried away with this birthday present for a friend. Elm box and jeweled 1.5 inch hobby vise.
My friend liked it though.
--earlgo
ctwo
Post by ctwo »
I like the patterns. I recall now seeing someone do it with a pencil eraser dipped in polishing compound.
