I think the idea in not turning on the magnet when grinding the bottom is so the chuck is not distorted due to surface anomaly on the chuck top.Harold_V wrote: ↑Sun Jul 17, 2022 3:33 pm I would suggest that the bottom would be ground only once, and that would be BEFORE the top is ground. That way you grind the top parallel to the installation when built. I would use the magnet to hold the chuck to the machine table. That duplicates how it is applied when being used.
It is unusual for the magnetic chuck of a surface grinder to be removed once installed. If, by chance, you remove yours regularly, it may become necessary to regrind the base, but careful handling should limit that need. Draw filing the base when re-installing should be more than adequate.
That might be your problem. Most folks don't use stones to grind, they use wheels. Stones don't make very good wheels.I think my magnet has an aluminum bottom. My experience with grinding aluminum is that it fouls the stone.
Recommended abrasive for grinding aluminum is not aluminum oxide, which I suspect is what you're using. For aluminum, a hard silicon carbide wheel would be the choice. Please note that the green aluminum oxide wheels are NOT that choice. The wheel you'd benefit by using would most likely be shiny black in color. The green wheels are usually very soft, which is exactly wrong for aluminum.
I have not ground any of the table or chuck. I did the 5 block test just to see where we are as-is.
I need to make/buy a wheel puller, and I'd like to make/buy a couple more spindles, and then set up for balancing a small set of wheels.
