Roller chain lube?
- Greg_Lewis
Roller chain lube?
I've got an RMI transfer switcher that runs with roller chain between the truck axles. I've tried motorcycle chain lube and a couple of other products that are labeled as chain lube but the chains pick up dirt and crud regardless. What might you suggest for a good chain lube? THANKS!
Greg Lewis, Prop.
- warmstrong1955
Re: Roller chain lube?
Bel Ray chain lube.
Spendy, but it drys, and stays on there longer than most. Most motorcycl shops carry it.
- Greg_Lewis
Thanks, WArmstrong. I'll check that out.
I see you're in Northern Nevada. If you're going to the Sac meet look for me.
Greg Lewis, Prop.
Greg,
I use Boeshield T-9 Chain Lube on the chains in our locomotive.
Good Luck,
Terry
Good Luck,
Terry
- Greg_Lewis
Thanks, Terry.
Greg Lewis, Prop.
