As followup to my 1/3 scale center cab loco restoration - Looking for ideas to acquire, or fabricate, window trim... for 3/16” Lexan window panes. Windows themselves are generally around 6”x8”, and 8”x12”. ideally should be able to open by mounting on small hinges. Smallest likely to be 4”x5”.
The trim should be somewhat decorative, but also functional, as it should hold the glass/plastic panels in place, and will protect the edges from chipping and cracking. Also, from a modeling perspective, unframed plastic windows in a locomotive cab are just plain cheesy looking- not very representative of modeling the prototype... also should enable the windows to seal shut against the window framing and sheet metal body.
Iam a little stumped on ideas for fabricating something, as I don’t want a three month project trying to machine a bunch of one off frame members...
So looking for recommendations on how to accomplish this.
Thanks much,
Where to buy Window trim
- Dick_Morris
Re: Where to buy Window trim
3D printing is a possibility, but many of the reasonably priced consumer resin printers are too small. Some are just stating to come onto the market for for $700- $800 that would print your frames in one piece if you print at an angle. All you have to do is find someone on the bleeding edge of the hobby. Larger sized filament printers are more common, but don't give as good a finish.
I've had good luck with this type of thing using RTV molds and castable resin from wood or metal originals, but the material can be a bit pricey. Look for Alumalite on U-tube for some ideas.
I made some sliding cab windows from brass bar with a groove rabbited into it and then soldered around a piece of glass. There were only one or two causalities because of unequal heating of the glass while soldering. You might also look for folded some brass or aluminum channel. Fitted carefully you could glue it in place with the glass providing the structure. It would give a finished appearance but wouldn't be very decorative. Micromark has some tiny hinges and Dumas was the the most reasonable price I found for very small piano hinges when I needed some a few months ago. (They aren't really brass, but brass plated steel.) Both of these may be too small for you.
For the rubber window holding trim Google- Trim-Lok. They also have a store on Amazon. Look at their one and two piece gaskets.
I've used their trims long ago but not the window holding stuff.
Denny
Denny
"Measure twice, curse once."
- Greg_Lewis
Give some thought about Lexan panes. They will scratch much more easily than glass. As to hinges, if you search through some of Jack's posts he's made hinges in special sizes and the process is easy enough that even I was able to make some. I also found some in the dollhouse suppliers online. That might also be a source for some decorative moulding; I've seen it there but not sure what you're looking for.
Drop us a note at Precision Steel Car and will send you picture of our window trim. It has an H cross section to hold the window in place. Designed for 1:8 scale but we have 2 versions to accommodate 1/16” material and another for 1/8” thick material. Might be worth a look.
Sincerely
Paul Vernon
PSC
Sincerely
Paul Vernon
PSC
McMaster has everything lol.NP317 wrote: ↑Thu Sep 02, 2021 9:47 pm Perhaps something useful here:
https://www.mcmaster.com/trim/
I think the aluminum channel with a "slippery plastic trim" insert would make a great slide/frame for the windows.
Look into that special aluminum soldering/brazing rod for the corners.
The secret to nice sliding windows is keeping them lubed with dry silicone spray.
