Aluminum switch points
Gra2472
Post by Gra2472 »
Hello all
I have been working on building a loop of track around my house and need to build a couple of switches. The problem that I have is that the rail I have is an older style of aluminum rail, much smaller that the rail commonly available today. Its 7/8" tall with narrow railhead. Its sort of between 1" scale and 1.5" scale rail. I purchased a set of points from Allen Models, to see if it would be close enough to work. Unfortunately, they just won't work. I need to find a way to build some points to match this rail. I know that machining the rail into points will work, but it is definitely ideal. However, my railroad is not a huge club layout for 4-8-4s pulling the evening mail and such. I only run a mogul, and a couple of small electrics.
I wanted to get some ideas and opinions about using aluminum rail for points before I start cutting up rail. Thoughts?
Garrett
Owner/Builder
Willow Creek & Orchard Valley Railroad
7.5" Allen Mogul
The railroad is almost done.
G. Augustus
Monte Rio, Ca.
ChipsAhoy
Re: Aluminum switch points
Post by ChipsAhoy »
Under the stock rail, in the switch, perhaps 1/8" tie plates (shims).
tomc
Post by tomc »
cant u modified the Allen points to work? Some pics would b e nice.
Tom C.
tom_at_srclry_com
A student of the Southend RGS!
makinsmoke
Post by makinsmoke »
Lots of folks make them from steel angle.
Use 3/4” x 3/4” x 1/8” and as someone suggested put shims under it. Make sure the shims go all the way across. You don’t want the angle to fall into a little gap and lower the top.
Benjamin Maggi
Post by Benjamin Maggi »
Have you considered stub switches? If you aren't having much run they would probably work fine. Just have a large enough signal target to see at a distance if the points aren't lined up properly.
Gra2472
Post by Gra2472 »
I have been working trying to the larger points from Allen Models to work, but there just isn’t a good way to do it. Besides being only 7/8” tall, the rail head is too small at 7/16”. It requires lots of complex shimming to get them to line up. I have a stub switch that I built for the engine house lead, it works well, but I am thinking about the eventual oops, when someone forgets that its a stub switch, and the train lands on the ties. I have a bunch of 3/4” angle iron, and I have been mulling over how to use them.
7.5" Allen Mogul
G. Augustus
Monte Rio, Ca.
Gra2472
Post by Gra2472 »
Here’s a picture of a stub switch in progress. This is was done with much help from a couple good friends from the Sacramento Valley Live Steamers who came up to the river to escape the heat.
7.5" Allen Mogul
G. Augustus
Monte Rio, Ca.
Gra2472
Post by Gra2472 »
7.5" Allen Mogul
G. Augustus
Monte Rio, Ca.
Dick_Morris
Post by Dick_Morris »
I don't remember the details, but long ago we had some switches that had a steel insert/wear piece bolted onto the last few inches of the point.
Your small rail may have been what was called "Culp rail."
One problem with a stub switch is that a lack of attention results in running the train onto the ties. Been there, done that.
DRS_RR
Post by DRS_RR »
there was this article on Discover Live Steam on using angle iron to make points...
https://www.discoverlivesteam.com/magaz ... index.html
Dave
tetramachine
Post by tetramachine »
I have some west coast AL rail 1' tall, 1/2 wide head. Sort of transition piece. PM if interested
My wheels don't slow me down
