Where can I find 1/8 tee barbed for air brake line?.
johngraser
Post by johngraser »
I'm trying to find 1/8" barbed tee out of metal or plastic for air brake lines.
Any recommendation of where to get them?
FLSTEAM
Re: Where can I find 1/8 tee barbed metal or plastic for air line?.
Post by FLSTEAM »
1/4" Instrument air tubing is just over 1/8" I.D. I have tee's for this tubing which measures 3/16" O.D. plus the barbs.
JB
ccvstmr
Re: Where can I find 1/8 tee barbed for air brake line?.
Post by ccvstmr »
John...check out Clippard.com. See if you can find a local distributor. I'd stay away from plastic fittings. Seen those get mangled under cars (particular if mounted on trucks). Was really difficult to find an air leak when one of those plastic tees got cut.
Would caution you...not all 1/4" od x 1/8" id tubings are the same. Minor deviations in tubing barbs...and the slide on connection won't seal well... or worse, can't get the tubing on the barb.
Another helpful hint...use a small dab of Teflon or silicone grease smeared around the tubing barb before pushing the tubing in place. Polyurethane tubing can be a challenge to slide on a dry barb. Carl B.
johngraser
Thanks, I was able to find a local distributor.
John
mspetersen
Post by mspetersen »
Have you considered truck air brake line fittings? They come in Tees, 90s, 45s, straights and many variations. Available in DOT style with a tube support or without (non-DOT) Both come in push-Lock type and compression style.
Mark Petersen
12" x 36" Logan Lathe
Steven E. Kuhn
Post by Steven E. Kuhn »
I agree Clippard fittings are what I use.
Steven E. Kuhn
hoppercar
Post by hoppercar »
Clippard fittings had them
