Bone stock LE Pacific Project
1.5" Scale
7.5" Gauge
4-6-2 Pacific
Loco:
Welded Steel Boiler with rolled copper flues
Slide Valve, before 80s redesign
Chassis-on-air
Smokebox throttle
Stack, Domes, cab, safety valve housing, turret housing, etc.
Oil Pan
Axle Pump (not installed)
Gauge Glass
Mechanical Lubricator
Some miscellaneous castings, small parts, and Coles valves
Partly finished tender:
Highly detailed riveted tender body. Great rivet work, and more than I'd like to count.
Draft Gear, buffer plate, step castings, etc.
Tender frame and floor
Complete Andrews trucks
Misc:
Complete set of drawings
Dummy K2 dynamo
Pictures definitely don't show everything.
Doesn't include running board castings. No grates or burner. Comes with a sheet metal oil pan that would work for oil or propane burning.
Tender has 99% of the pieces, but needs final assembly, sealing, piping, etc.
also includes a heavy duty double decker stand on big casters.
Great project, sad I don't have the time for it anymore.
Asking $13,500 USD. Located in San Jose, CA.
Here's a link to more photos. If you're not familiar, imgur.com is just an image host.
https://imgur.com/a/TC6HGFD
1.5" scale, 7.5" gauge LE Pacific Project
