Hi Folks;
The Superscale 14-09 (Straight inlet flange connections) and the 14-11 (Straight inlet spanner nut connections) are back in stock. The 14-09's are $400 each and the 14-11's are $350 each. These come with the isolation shut off valve, 3/8" tubing solder connection bushing and hardware on the flanges for non-functional detail. Boiler bushing connection size is 1/8" NPT and is integral to the check body casting. Coming soon will be the 14-10 and 14-12 Hancock checks which feature the lost wax cast inlet elbow.
Also, Superheater identification plates are available for $22 each.
Please shoot me a PM or email if your interested in these or any other Superscale items.
Thanks
Dave Bortz
DSBortz@comcast.net
Superscale Hancock Check valves back in stock
Re: Superscale Hancock Check valves back in stock
They look great Dave! I’m happy to see Superscale coming back. I still have a list of parts that I need.
Andy Pullen
Andy Pullen
