WTB Baker valve gear castings
Hi All, Does anyone have a set of Roger Goldmans Baker valve gear castings laying around? Yes I've tried to contact Roger and there's been no response..
Thanks..
Thanks..
Re: WTB Baker valve gear castings
Jim Krieder uses a different style baker valve gear for his Nickel Plate Berkshire that may work for you. It has a smooth outside “channel faces inward” and better looking castings for the inner gearing.
Thanks… I did see those..little giant wrote: ↑Tue Jun 07, 2022 5:15 pm Jim Krieder uses a different style baker valve gear for his Nickel Plate Berkshire that may work for you. It has a smooth outside “channel faces inward” and better looking castings for the inner gearing.
I have a set.
1954lafrance,
message sent..
whatever happened to these patterns? does Roger still have them?
I have a set of long frame baker gear from Goldman I have been told
there was a post on here a bit ago, with someone announcing they had purchased Roger's line of products and had available castings again. so hopefully finding the baker you wanted won't be an issue now
That was Steve Gnas, who's calling the business Live Steam Locomotives: viewtopic.php?t=112800
John Brock
