WTB steam pressure regulator valve for boiler atomizer
I am looking for a steam pressure regulator valve suitable for use as the atomizer line on a 3 HP boiler.
Clippard has one but they are custom order with a 25 piece minimum order.
I'm not rich enough for those...
Any suggestions? This is for my steam launch, pic attached.
Thanks.
Thanks.
Re: WTB steam pressure regulator valve for boiler atomizer
Are you in a position to build one?
Bill S:
Build a steam regulator?
Yes, assuming my shop is properly equipped.
I am sure there are designs available for "hobby" manufacture but I have not found those yet.
Your collective ideas are definitely welcome!
Thanks.
Thanks.
- makinsmoke
Russ,
Is that a 25 piece minimum or 25 dollar minimum?
Russ, is this the kind of thing you are looking for?
http://ibls.org/mediawiki/index.php?tit ... _Regulator
Very nice boat Russ I bet that's a peaceful ride
Jim
Jim
No problems just solutions.
That was a 25 UNIT order. I can't afford that.
That remains a possibility to consider.BAdams wrote: ↑Sun Jun 05, 2022 5:06 pm Russ, is this the kind of thing you are looking for?
I already have the required .003" thick stainless steel sheet to make the diaphragm.
Hmmm.
- makinsmoke
Russ,
You might see if you can buy Clippard items from suppliers versus from Clippard direct.
Also, there are numerous Clippard regulators on eBay. You’d have to confirm the one you are looking for, but that’s another potential source.
Take care,
Brian
Take care,
Brian
Brian:
Thanks for that advice. Been there done that, and probably should repeat that search.
That was my first try.makinsmoke wrote: ↑Mon Jun 06, 2022 7:42 am Russ,
[snip]
Brian
The dealer had to order them from Clippard. Minimum Clippard will make/sell = 25 units.
