WTB: Alco Type E Power Reverse
Looking to buy a 1.5" scale ALCO type "E" power reverse in working or nonworking condition. Would also consider a type "H" and type "G" as well.
Re: WTB: Alco Type E Power Reverse
Wish I would’ve noticed this sooner. Give a call to David, great guy and quality castings.
http://www.dmprototypes.com/reverse.html
has anyone used his castings to do a dummy vs making it fully functional ?
- Chris Hollands
Yes the one I have installed is non working it is fine just leave the seals off the piston or similar
how do you attach it to the stand in the cab? I've seen a dummy ( not as detailed as Moore'scastings) where the piston rod was extended out the back of body, then run to cab
- makinsmoke
Wouldn’t the piston rod be attached to the valve links?
It’s steam operated, right? The 940 has a butterfly handle in the cab marked FWD REV.
I’ll see if I can find a pic or two.
- makinsmoke
Ibls.org/files/2014/Alco%20Power%20Reverse%201019.pdf
Look down two posts for a functioning link
- makinsmoke
www.ibls.org
Click on the logo
7. Articles by category
Category:steam locomotive parts
Power reverse
Look down to the following post for a functioning link
Click on the logo
Power reverse
- makinsmoke
Two pdf’s, and a video by Dave Sclavi.
Geez, finally found a direct link:
www.ibls.org/mediawiki/index.php?title= ... verse#Alco
- Chris Hollands
A picture is worth a thousand words - is that the saying .
You make a double ended linkage and a forward / rev lever in the cab if I understand what you are asking
- makinsmoke
Hi Chris!
Yours is interesting. I’ve seen the unit mounted further back towards the cab, with the linkage from the reverse lever coming in one end to the top of the cylinder, probably connected to a shuttle type valve? The cross head and piston rod connect to the valve linkage. Perhaps yours is designed this way as it is non- functional?
Moderators. Maybe we need to take this portion of our program off the For Sale page?
Original discussion is about a dummy setup.
