8-1/2" cross compound air pump drawings
For sale; 67 drawings for the 8-1/2 cross compound air pump in a PDF file. Send $25.00 through PayPal to branchlineprod@msn.com
Once I receive payment I will send you the PDF file.
Thank you
Thank you
Re: 8-1/2" cross compound air pump drawings
These are Westinghouse full size drawings.
Jeff, are these for the 8-1/2 120 or the 8 1/2 150?
Marty, these are for the 150 ccp
Email sent
Is this offer open to more than 1 person?
Any plans to offer a single compressor?
Mark Petersen
12" x 36" Logan Lathe
Just following up on my payment on May 20th for the air pump drawing set.
Thanks,
Dave
Thanks,
Dave
The set must be for the 150 export version, same as the USA 150 B version. The bolt sizes are usually all noted in whitworth and US standard.
There are close to 100 drawings in the complete set.
I just reviewed - you must be correct. I see reference on one print to "....for Japan...", along with Whitworth threads throughout the print.
Is it safe to assume that the overall compressor remains the same, just conversions to Whitworth threads are the "only" changes?
Yes, all same. It was a world standard by that time.
Some rr's designed their own like the PRR that built some for 300psi steam.
I have the list of drawings for the complete 150cc set that ill get my hands on again soon, I'll make sure everyone gets the list.
Just following up on my payment made on the 15 July. Still waiting for the drawings to be emailed through
