All,
These parts are all printed and tested now. Between the time I first printed these Shapeways changed their rules for sizes. I had to upsize the lettering on the lid to meet the new larger sizes. Honestly it doesn't look too bad a bit larger. I also made some dummy fittings for them. The box is hollow of course to run your wires. I can easily add another box with different size holes if anyone wants that. You might need to adjust the holes to get a perfect fit. The new lid with the larger letters fit perfectly on the box when I assembled it tonight. Bolts are 00-90.
The handrail stanchions are from Mercer Loco. Works.
There will be a plain lid too, it seems some engines had the plain lid or a mix of both. Its modeled but I haven't printed one out as a test yet.
These boxes were used on practically all PRR engines(I couldn't find any on the T1's however, maybe they are under the shrouding, LOL)
https://www.shapeways.com/shops/rivet-counter-details
Thanks,
Paul
PRR electrical junction box parts
