3-3/4" Scale Sunbeam Headlamp
- JBodenmann
Hello My Friends
Here is the new 3-3/4" scale Sunbeam headlamp. It features a 5" diameter nickel plated copper reflector. 5" diameter steel tube main body. 15 brass investment castings. Photo engraved builders plate. One electrical circuit for the number boards and another for the main bulb. Assembled and painted for $1150.00. Limited number available.
Jack
Jack
Re: 3-3/4" Scale Sunbeam Headlamp
Do you make one in 2.5?
- JBodenmann
Hello My Friends
The Sunbeam Headlamp is only available in 1-1/2" and 3-3/4" scale. If there isn't a 2-1/2" scale version available I would consider making one. But I wouldn't want to produce something that is already available. I wouldn't have made a 1-1/2" headlamp if I knew David Sclavi was going to re introduce his.
Jack
Jack
The only 2.5” scale headlight I know of is the one Tom Artzberger sells, but I don’t know how readily available it is.
-Tristan
Projects
Projects
- Steve DeLoach
I am interested in at least a couple of these. Please message me when you can.
- JBodenmann
Hello My Friends
I have two of theses headlamps left. Price is the same as before.
Jack
Jack
Outstanding!
Jack
Jim Ferguson here long time. Hope your doing well!
I’m interested in the headlight. Marty Knox is building a Sweetcreek for us. Can you call me 714-598-9248.
Jim
Jim
