WTB Tear drop Throttle Valve
Where can i buy a tear drop throttle valve that will fit in an allen americans steam dome??? How much will it run me?
Re: WTB Tear drop Throttle Valve
I am not familiar with a "teardrop throttle valve" for steam.
Educate me please?
Educate me please?
Tear drop generally related to the shape of the port...not how it is actuated.
I have seen tear drop rotary throttles, push pull linear throttles, ball valves with tear drop openings and upright slider throttles.
Almost all can be made to fit in the described loco, but generally have to be made to fit...unless you are designing the boiler internals around the throttle to begin with.
Most of the off-the-shelf throttles I have seen come from the UK.
AKA “v-port (or v-ball) ball valves”. I looked into this, but everything I found were larger pipe sizes, such as 1/2” npt or bigger.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Avco (avcovalve.com) sells v-port ball valves down to 1/4” npt, but you’ll need to find a distributor of theirs.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Thanks all for the education.
Appreciated.
Appreciated.
I think that some fuel valves are made this way for IC engines of the model/tractor variety... Might look at these antique valves.
Mike
Mike
