WTB classification lense
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Mjordan
Post by Mjordan »
I’m looking for a set of engine classification lamp lenses. I have no idea what make these are but I think they are 1.5” scale. Looks like Pyle style lamps. Any info where I can find lenses would be great.
I’ve seen a couple places that sell the whole lamp but all I need is the lenses!!
rrnut-2
Re: WTB classification lense
Post by rrnut-2 »
Railroad Supply has lenses, call Mike after 6pm.
Jim B
Dick_Morris
Post by Dick_Morris »
I have a bag full of lenses. If mine are the right size you are welcome to a few. What size do you need?
Mjordan
Post by Mjordan »
Dick_Morris wrote: Mon Aug 08, 2022 5:00 pm I have a bag full of lenses. If mine are the right size you are welcome to a few. What size do you need?
I will measure this evening! Thanks
Highiron
Post by Highiron »
Contact me off list at highiron@aol.com I make lenses and also make an adapter ring to make them fit other openings
Mjordan
Post by Mjordan »
They measure just at an inch
Highiron
Post by Highiron »
Wow those are big what I have won't work I'll be making clear lenses shortly that will measure close to that but I won't have them done till fall
Greg_Lewis
Post by Greg_Lewis »
If you can't find what you need from live steam sources, years ago someone posted here that there is a GE push button lens the end of which can be cut off and used. The lens has circular grooves in its backside similar to the Fresnel lenses that were used in the lamps. The part number is CR104PXL07. Then add to that number a letter for the color, y, r, g, etc.
Here are a couple of links:
https://www.ebay.com/itm/203032226315
https://duckduckgo.com/?q=CR104PXL07&t=opera&ia=web
Greg Lewis, Prop.
Greg_Lewis
Ah, found the thread. Scroll down for more on the GE lenses:
http://www.chaski.org/homemachinist/vie ... lit=marker
Greg Lewis, Prop.
Dick_Morris
an inch
Mine aren't that big either.
Mjordan
Post by Mjordan »
Greg_Lewis wrote: Fri Aug 12, 2022 9:08 pm If you can't find what you need from live steam sources, years ago someone posted here that there is a GE push button lens the end of which can be cut off and used. The lens has circular grooves in its backside similar to the Fresnel lenses that were used in the lamps. The part number is CR104PXL07. Then add to that number a letter for the color, y, r, g, etc.
Thank you so much!!! I just ordered two clear to try out then will order two green!
