smoke coming out of 9729 lathe motor connector box
John R
Re: smoke coming out of 9729 lathe motor connector box
Post by John R »
These pictures show the new motor mounted on the machine and a cover I made for it to keep shavings/chips off. The new motor housing is ribbed to assist with cooling.
liveaboard
Post by liveaboard »
You'll want to keep the smoke from coming out of the new motor.
