I piped my Stuart Turner D10 steam engine into a 125psi industrial steam boiler. You can see it here on YouTube.
https://youtu.be/ZtUQzSS__78
Stuart Turner D10 Steaming on Industrial Boilers.
Re: Stuart Turner D10 Steaming on Industrial Boilers.
Steam is steam...as long as it is dry and of the correct pressure.. matters not the source....
I'm waiting for someone to post a steam engine running on nuclear derived steam!Bill Shields wrote: ↑Tue Jun 28, 2022 7:21 pm Steam is steam...as long as it is dry and of the correct pressure.. matters not the source....
they rather frown upon people 'tapping' into their steam stream...
generally they are a closed system, and they carefully monitor make-up water...not that this would use a lot...
that and the pressures are generally WAY BEYOND anything our dinky models could handle...
Hence, the wait.Bill Shields wrote: ↑Wed Jun 29, 2022 11:09 am they rather frown upon people 'tapping' into their steam stream...
Might as well wait for one tapped into a supercritical steam cycle boiler as well..
There is one just up the road outside phl airport...but alas not open to the public...
