Incremental misery
Greg_Lewis
Re: Incremental misery
Post by Greg_Lewis »
Bill Shields wrote: Mon Jul 11, 2022 3:22 pm isn't much of this what cardboard and a magic marker were created to overcome?
Yup. That's what I finally resorted to. After I discovered the uneven bottom and the reverse tilt. Which, of course, didn't appear until after I discovered all the 857 other things I discovered that the evil shop genie put there to mess with my brain.
So far today the humidity is at 17 percent and it's an even 100 outside right now so the swamp cooler is working fine. The air coming out of the plenum is 78 and the shop is holding at about 86. So the acid test for the a/c unit is still in the future.
I picture the lower angle supports make from turnbuckles.
Rotate until correct.
'Sounds simple, anyway...
Greg_Lewis
NP317 wrote: Mon Jul 11, 2022 4:36 pm I picture the lower angle supports make from turnbuckles.
Where were you when I needed you? :D
Sorry... :cry:
atunguyd
Post by atunguyd »
This sums up this threadImage
Sent from my SM-S908E using Tapatalk
At least there is a headlight to guide the way down the tunnel of darkness...
SteveR
Post by SteveR »
And I’m out of beer.
There's the problem. Everything else just describes a regular project. :D
OTOH - putting one of those units in my garage (stucco wall and mounted 7 feet up) was one of the best things I have ever done. Hope you enjoy yours too!
SteveR
Not enough measuring tools...
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
