FM Dewatering pump
FM Dewatering pump
Hi All, I have this rusted up pump attached to a B&S motor I have been trying to separate pump from motor without success, any thoughts?
If it ain’t broken keep working on it until it is .
Geo
Geo
Re: FM Dewatering pump
Phosphoric acid may be the solution, although there's no guarantee. It's gentle---shouldn't do any damage. If you'd like to experiment and you can see a way to do it, use some Coke. As crazy as it may sound, it will loosen rusted connections if it can be applied and allow to remain to do its work.
I have used PB Blaster which I have had great success with and it still won’t free up.
Geo
Geo
Heat will work, but it will likely do some damage. All depends on what's near the heated areas. You'd have to heat slowly, to avoid cracking the cast iron. If you get it hot enough for the rust to turn black, it should come apart. Most likely not a solution in this case, though.
I'm not familiar with PB Blaster, so I have no opinion.
I have used salt and vinegar, which dissolves rust nicely. You'd probably have to dismantle the engine to try it. That would demand new rings and gaskets upon reassembly. If you choose to try this approach, the entire assembly should be submerged to prevent a line being etched where it would protrude from the solution.
Is that a screw head in the center of the impeller? If so, probably needs to be removed as part of the process. Any chance of finding drawings?
A couple of gallons of ATF in a tub and let it soak for a few days
- liveaboard
I assume that screw is what's frozen?
Weld a handle to it to unscrew it with. the heat will be intense but highly local and the expansion / contraction will break the rust.
It could be a left hand thread, so work it both ways.
