Socket head cap screws
earlgo
Post by earlgo »
Having been a mechanical design engineer for 50 odd years, I ran across something a couple of years ago that made me wonder. I found a #12-24 tap and die in the box of "inventory" that my dad had with the Atlas lathe. I didn't think any more of it because it was an "odd" size. Last year I found a #12-24 tap at the local Ace hardware and bought it just to see how soon it would be replaced. A replacement was there within 2 weeks.
Recently just for fun I ordered a box of #12-24 socket head cap screws from McMaster-Carr and it came in a green box marked with no name, just a phone number. The screws are stamped 'CAMCAR'. Normally McM-C screws come in a black box marked "Brighton Best" with no stamping on the screw.
Neither the Unbrako Socket Screw Selector nor the Holo-Krome Socket Screw Selector slide cards list a #12. #0,1,2,3,4,5,6,8,10 are listed but then jumps to 1/4" and larger fractional sizes.
A #12 screw is .216 diameter right between the .187 diameter #10 and the .250 diameter 1/4".
#10, #12, 1/4in
#10, #12, 1/4in
Do any of you wizards know why #12 screws are not commonly used?
--earlgo
mklotz
Re: Socket head cap screws
Post by mklotz »
Electronic racks are one place they are used...
https://www.racksolutions.com/news/data ... explained/
I believe some old woodworking equipment, e.g. planes, used that size for adjustment screws but I'm not a woodworker so take that with a grain of salt.
Regards, Marv
Home Shop Freeware
Post by John Hasler »
They are common in electrical equipment.
Russ Hanscom
Post by Russ Hanscom »
Probably manufacturers trying to simplify their inventory. I have a #12 tap and die, and a few other weird ones, legacies from grandfather. Hoping to keep then as curiosities only. Most are close enough to something else as to not be really needed and they are an invitation for a careless person to use the wrong size.
Steggy
Post by Steggy »
In the past, I've seen 12-24 machine screws used in some power tools—it seems to be a rarely-used size these days. I have a 12-24 gun tap and a 12-24 die in my tap-and-die set, but can't recall if I've ever used either one.
CamCar is/was a large manufacturer of socket screw products. Dunno if they're still around.
My Craftsman Handbook of Taps, Dies and Threading Accessories (published in 1968) lists 12-24 as a stock size. However, my Blue Devil slide card jumps from #10 to 1/2".
BigDumbDinosaur wrote: Sun Mar 07, 2021 6:08 pm my Blue Devil slide card jumps from #10 to 1/2".
½"? Not ¼"?
Steggy
Post by Steggy »
Harold_V wrote: Mon Mar 08, 2021 2:53 am
½"? Not ¼"?
Yep! It's supposed to be 1/4. I tried to fix that after I saw my error and had already posted, but the forum software refused to let me do it. It was within a minute or two after posting, so it was a case of being timed out.
earlgo
Post by earlgo »
Russ Hanscom wrote: Sun Mar 07, 2021 4:29 pm Probably manufacturers trying to simplify their inventory. (....) Most are close enough to something else as to not be really needed and they are an invitation for a careless person to use the wrong size.
Oh, that explains everything. I have often used #0, #1, #2, and #3 screws and the hardware is full of them in different sizes, and the taps and dies are there, too. OK, not so much. But strangely enough McM-C carries socket head screws down to #0000-160! good grief, I would hate to drop one in the lathe chip tray. Major dia is .021 with 160 threads per inch and head size of .035. Thread pitch would be .006. My thread wire kit didn't have wire for checking those, for sure.
Still not a useable answer as to why #12 screws are not that commonly used for other things than electronic equipment.
My next project will use them if it is relevant. More or less to tick of the next user, I guess. :D
--earlgo
mcostello
Post by mcostello »
Can I have that #0000 in socket head set screw? What size Allen wrench is needed?
earlgo
Post by earlgo »
My error. The #0000, #000, #00 screws are slotted fillister or flat head screws. The first SHCS McM-C lists is the #0 with a drive size at .050.
I've got a design going with the #12 screws, though. It is just a drill press stop spindle clamp, so no-one will know until the removal time comes. :lol:
--earlgo
earlgo
Post by earlgo »
Cruising by the Tap display at the local ACE I was somewhat surprised to see a lone Irwin Hanson #14-20NS tap hanging there. The #14 screw is (14 x .013)+.060 inches in diameter or .242. So a #14-20 is approximately .008 less in diameter than a 1/4-20 UNC. Being curious, I checked the screw and bolt department and found no #14 screws. Quite a number of #12 Phillips head, though. If one searches on the internet the results generally come back as 1 4 - 20 and Amazon and others have 1/4-20 UNC fasteners, but no returns on the #14-20. Neither MSC or McM-C lists them.
Once again, why?
I'll keep my eyes open for a #16 tap.
It might be fun to make some kind of fixture kit with #14-20 tapped holes in it and supply the kit with 1/4-20 screws just to get a chuckle when assembly was attempted. :twisted:
--earlgo
It's been way too many years since I referred to the H28 Handbooks, but within them you are likely to discover why those odd threads used to be common, and why they are no longer readily available. Seems like the effort to standardize thread sizes came quite late in the scheme of things.
Another interesting thought. We often discuss imperial versus metric. The US has held steadfast with the Imperial system, but then, has it, really? The US gallon is not the same as the British gallon. Are they both considered Imperial?
Seems we have a blend of measuring systems.
