Tactical error....
Greg_Lewis
Tactical error....
Post by Greg_Lewis »
Ooops. I admit to having done this once, but with a much, much, smaller machine and a much, much, smaller piece of material. In my case the power switch was at the left end of the headstock, which made things, uh, "interesting." (Note sig line and avitar....)
https://youtu.be/C8ZJa2HSkYE
Steggy
Re: Tactical error....
Post by Steggy »
Greg_Lewis wrote: Wed Sep 09, 2020 9:00 pm Ooops. I admit to having done this once, but with a much, much, smaller machine and a much, much, smaller piece of material. In my case the power switch was at the left end of the headstock, which made things, uh, "interesting." (Note sig line and avitar....)
I, fortunately, have not committed that sin. Bet the boss was none too pleased.
Heh! Looks much like my experience. I had taken a part time job in a small machine shop when I was about 21 years old. I don't remember the details well, but I recall that I had to do some work on a (long) piece of 3/4" mild steel. Amazing how a piece like that can move a machine that weighs a ton or more. I strongly suspect that what you saw in that video was very much like my experience. :oops:
Yeah, this was one of the things in my life that make me cringe. I should have known better-----the same thing I often think about marrying my first wife. The current model seems to be without the same flaws (or she tolerates me much better). We've been together for more than 43 years now.
Thanks, Greg. Things like that serve a very valuable purpose for those who might space it once in a while.
liveaboard
Post by liveaboard »
Having the stop lever within arm's reach saved me from this one.
Several times.
earlgo
Post by earlgo »
Did mine with a 2 ft length of 1/4" dia brass rod in a 12" Atlas. Glad I wasn't leaning on the belt cover. :shock:
--earlgo
tornitore45
Post by tornitore45 »
It happen to me too 3/8 drill rod. It beat to shred part of the shelf on the wall.
On a related subject... I put two switches on my table saw, one on each side, so I can safely reach one no matter haw I am feeding the part. The original switch was hidden below the table extension. Now it just act as safety to disable the other two.
Greg_Lewis
Notice how it takes out the tool box atop the guy's rollaway. At least it wasn't a Gerstner.
earlgo wrote: Thu Sep 10, 2020 9:28 am Did mine with a 2 ft length of 1/4" dia brass rod in a 12" Atlas. Glad I wasn't leaning on the belt cover. :shock:
--earlgo
Same lathe, same stock, but mine was a foot longer. As I mentioned above, the switch was at the headstock end, and the stock was whipping itself against the switch. And the power plug was behind that. I had to run outside and trip the breaker.
tornitore45 wrote: Thu Sep 10, 2020 4:18 pm ... I put two switches on my table saw, one on each side...
Excellent idea, Tornitore!
liveaboard
My table saw has a relay, and a kill circuit that runs to 3 buttons around the machine. Hitting any of them opens the circuit and deactivates the relay.
Lathe has VFD now, and that also has an emergency stop button. But actually, it's in the wrong place for this event.
Do we have a name?
Stock whip.
No, sounds like something cowboys use...
stock swing.
Sounds like a playground for kids...
Centrifugal runaway
Spinning rod of death
twirly bar
Greg_Lewis
liveaboard wrote: Thu Sep 10, 2020 5:49 pm My table saw has a relay, and a kill circuit that runs to 3 buttons around the machine. Hitting any of them opens the circuit and deactivates the relay.
Do we have a name?
Stock whip.
stock swing.
Centrifugal runaway
twirly bar
I'll suggest "dope slap."
earlgo
Post by earlgo »
I called mine, "OH CRAP!"
--earlgo
Post by BadDog »
I haven't done that (yet), but I suspect my response would have been substantially less PG...
Greg_Lewis
BadDog wrote: Fri Sep 11, 2020 12:43 pm I haven't done that (yet), but I suspect my response would have been substantially less PG...
Yes. Well... I do sometimes have to talk to my machines. My wife calls it "Navy language."
