And Parker 60's.....do not....as you know!
https://www.parker.com/literature/Quick ... ctionB.pdf
Help me Change a Kubota Quick Coupler
- warmstrong1955
Re: Help me Change a Kubota Quick Coupler
- SteveHGraham
Thanks. Very helpful. I might go for a couple of those.
I managed to get a 7/8" wrench on the coupler today, and I tightened it considerably more. It will be nice to be able to clean the oil off the floor and not have it return the next day.
- warmstrong1955
A note on that tightening thing......if you still have a leak....
It may work....but usually not. Pipe dope will set up after a short period of time. If you dope something up, and reassemble, and it still leaks....chances are, you missed a spot, or a bit of oil was still there, and you have some metal to metal. An additional torque....won't make that go away.
So.....pretty much maybe....but maybe not.
- SteveHGraham
That is good info to have.
I used a Vise Grip to tighten it initially, and I guess the torque I was able to apply was not that high, because it turned easily with the open-end wrench. I feel like I need to see how it works when it's tight before I make a judgment. I put a piece of clean scrap cardboard under it today before I left the garage.
