Today's Discovery: Wire Gauge Drill Bits for Carbs
Steggy
Re: Today's Discovery: Wire Gauge Drill Bits for Carbs
Post by Steggy »
b4autodark wrote: Tue Apr 30, 2019 3:48 pmI have an Anderson-Forrester GDK4080 kit, had it for years for doing oil, propane and natural gas burner orfices, really handy.
https://www.amazon.com/ANDERSON-FORRESTER-GDK4080
That link is 404.
Post by BadDog »
mklotz
Post by mklotz »
SteveHGraham wrote: Tue Apr 30, 2019 4:47 pm The one thing I wish I had is an index. I have to use calipers to figure out which drill bit is which.
Huot sells an index...
https://www.amazon.com/Huot-10400-Drill ... 190&sr=8-4
although I find this one-at-a-time dispenser style...
https://www.amazon.com/21pcs-Twist-Micr ... 189&sr=8-9
far easier to use plus it's almost impossible to lose other drills while extracting the one you need.
Regards, Marv
Home Shop Freeware
Post by SteveHGraham »
Thanks for the tips on indexes. Or indices, to be stuffy about it.
My impression from reading about tiny bits for carburetors is that carbon is better than HSS because it will flex instead of breaking. Does anyone know if that's true?
Post by spro »
It makes sense to me. It is often unlikely that the alignment of the actual port is the same as the tiny drill. It must follow that harder port while drilling the softer junk. Consider root canals or don't :( The drills are miniature and short but still flex.
