Melting Transmissions
RCW
Re: Melting Transmissions
Post by RCW »
BobS wrote:I use just trans cases and alloy wheels for my aluminum casting because it's good stuff and I can get it from a transmission rebuilder at the wholesale scrap price and they come steam cleaned to boot. 8) I started out busting the cases up with a sledge but that's a job so I finally went out and bought a log splitter to break them up. In just a few minutes I can have a case broken up and have a 1000 lbs of cases in couple hours down to the size to fit the my crucible. :roll: This is also a good time to remove any steel pieces that are still in the cases to prevent iron getting in the melt later. A gallon of gas used this way will go a lot farther then the same amount used to try and melt the cases down to size. :?
Alloy wheels are little more trouble but if you watch the style you pick up that are spoked and not a flat dished they usually go easier. :wink: Bob
How can you be sure there's no magnesium wheels in the mix?
Bob
--Bob
