Vacuum pump from throwaway compressors?
ChrisPer
Post by ChrisPer »
I want to make a vacuum pump for debubble-izing investments, vacuum pressing poster block mounts and maybe sucking 20-litre oil drums flat to impress the kids.
I know some compressors, like Root blowers, run equally well in reverse and others do not.
Has anyone here tried cutting the motor/compressor out of a fridge and using it for a vacuum pump? Or maybe a car aircon compressor with a washing machine motor?
Hanz
Re: Vacuum pump from throwaway compressors?
Post by Hanz »
Some use a refridge pump to suck down AC systems. Mine is a little overkill, the 220V AC compressor from a home central air unit, using the suction side to suck down automotive systems.
[url=http://www.hanzenginehouse.com]www.hanzenginehouse.com[/url]
WLW19958
Post by WLW19958 »
Hey Hanz,
I agree that the electric compressors out of an old window A/C unit work great! Just don't forget to squirt a little refrigerant oil in the suction side once in a while. A new compressor used to evacuate can pull 29.5" of mercury and a good used one should be able to pull 29". Not too shabby!
Regards,
Webb
steamin10
Post by steamin10 »
Any fridge or AC unit that is still working (pumping ) is a good candidate. One recently made was converted by drilling a TINY hole in the top of the hermetic case to relieve leak pressure and screwiing the blobby thing to a piece of plywood with rubber feet and adding a houshold lite switch for the off and on...If your unit loses oil out the hole it will quickly run the unit dry and score the bore on the pump.. Bingo- you are done... These units work fairly well and have been used by enterprising guys like me to do vacuum jobs on equipment.. Dont forget the valve sets....Dave..
