Suggestions for laying out a wheel pattern
Adirondack
Post by Adirondack » Wed Sep 15, 2021 8:04 pm
Hi folks. I'm working on designing the pattern for a large estate-railway wheel. Given the deep dish shape and cross section, how would you suggest setting up the match plate? The top plate seems straight forward, but getting the deep dish in the back is where I'm lost.
Thanks!
Chris
Adirondack Car & Foundry
Check out our projects: https://www.facebook.com/ADKrail/
Visit our ALL-NEW online store: https://adirondackcarfoundry.square.site/
A little locomotive with 4 wheels on the track is a lot more fun
than a 1/2 finished one with 16 wheels on the bench!
ChipsAhoy
Re: Suggestions for laying out a wheel pattern
Post by ChipsAhoy » Thu Sep 16, 2021 10:22 am
Look up "cheek". As in Cope, Cheek & Drag. That may help you get where you need to be.
I tried it on a journal box... made a hellofamess because I didn't think it all the way thru first.
Scotty
FKreider
Post by FKreider » Thu Sep 16, 2021 6:00 pm
Match plate will have to have an irregular parting line.
Basically illustrated in this video by MrPete where he does this basic concept with a mini frying pan as a demonstration:
https://www.youtube.com/watch?v=Wmaku9GZdBQ
(He flips the match plate over in the first 2 5seconds of the video and I think you will see what I mean.)
-Frank K.
patternguy
Post by patternguy » Thu Sep 16, 2021 6:57 pm
Adirondack, I have a YouTube channel Dave Clark The Pattern Guy. I do some segments called chalk talks. I will make one showing how I would go about making this project. As a matter of fact, I made a wheel similar to that a few years ago. I still have the pattern. I'll try to get the chalk talk out in the next couple days.
Adirondack
Post by Adirondack » Fri Sep 17, 2021 10:08 am
That would be awesome. Thanks!
Chris
jscarmozza
Post by jscarmozza » Fri Sep 17, 2021 11:41 am
My two cents, for what it's worth. If the foundry requires match plates then that's what you do, if you need a lot of wheels then you'll want to use a match plate, but if you're making just a few castings, a match plate is a lot of work, think about using cores. John
FKreider
Post by FKreider » Fri Sep 17, 2021 8:07 pm
In this day and age most match plates are CNC machined out of solid (tooling board or aluminum) and/or 3D printed and simply attached to the match plate. Sometimes its a combination of these two methods. In either case its "a lot" work in CAD/CAM but not so much in actual pattern making.
Fantastic 3D printers are available for extremely cheap so these methods are well within the average hobbyist's means - especially with the barrier to entry of CAD basically non-existent due to good free software.
Making a match plate the old school way is a lot of work but it's also a lost art in todays world.
-Frank K.
patternguy
Post by patternguy » Sun Sep 19, 2021 8:25 am
I got a video up for this subject. I, also going to do another one showing a match plate made from a mold. As soon as I figure how to post links I will do so. If anyone has other subjects they want me to touch on leave me a note.
ChipsAhoy
Post by ChipsAhoy » Sun Sep 19, 2021 9:41 am
Would it do to use "lost PLA" and skip the match plate altogether?
Scotty
Post by Harold_V » Sun Sep 19, 2021 3:38 pm
All that is required to post a link is to copy and paste. No buttons are required unless you wish to embed the video.
Adirondack
Post by Adirondack » Mon Sep 20, 2021 7:45 pm
Link for those who are interested.
https://youtu.be/kKxBMzeYQHM
BTW, I am running these in iron in batches of 24.
Chris
FKreider
Post by FKreider » Tue Sep 21, 2021 7:27 pm
Hi Chris,
Qty.24 at 14" is a good bit of Iron!
How are you making the pattern? I know you do a lot of 3D printing but 14" is fairly large... multiple prints and glued together afterwards?
-Frank K.
