Alloy of brass and zink in a home foundry
FKreider
Re: Alloy of brass and zink in a home foundry
Post by FKreider » Tue Aug 11, 2020 8:57 am
John Hasler wrote:
Mon Aug 10, 2020 8:45 pm
Zinc boils at 1665F.
Exactly, below the melting point of Brass which makes alloying a bit tricky in my experience.
-Frank K.
Post by Harold_V » Tue Aug 11, 2020 4:06 pm
Sure, Scotty, anything you can share is welcome. Most of us are learning, not pro's.
I have extensive experience in melting with gas furnaces, and the heavy use of fluxes. However, that experience is restricted to the melting of silver. I know that fluxing is really hard on not only the crucible, but the furnace as well. Brazing flux use that you mentioned earlier would most likely not be a good idea (for that reason), but the use of glass, as you suggested, may be far more forgiving.
I'd suggest that most any glass would work, so long as it is not borosilicate glass, which melts at a much higher temperature.
ChipsAhoy
Post by ChipsAhoy » Tue Aug 11, 2020 6:07 pm
You can see, if the weir shape does not fit the crucible, glass can eek around it. Not the end of the world, so far it floats and pops up out the vent & on top the sprue.
With a two person pouring shank, this requires a 3rd body.
Scotty
Post by Harold_V » Wed Aug 12, 2020 3:10 am
Thanks! Pretty simple.
ChipsAhoy
Post by ChipsAhoy » Sat Oct 24, 2020 10:51 pm
For those who haven't had the pleasure.... here is a genuine zink fire. It started when he removed the glass and dross. Should've waited until the crucible was out of the furnace and in the pouring shank. You can see the "spoonful" of glass and dross above the furnace, in front of the guy wearing the proximity gear. Managed to pour two cylinders and various other parts for the CliShay. Will have to wait for the machining to see if we were successful.
Scotty
jkimberln
Post by jkimberln » Sun Oct 25, 2020 1:48 pm
I had a couple of those yesterday. I was pouring brass and got it way too hot. Opened the lid and.... it's really bright.
