Cutting thin sheet metal
Sheet Metal Fabrication techniques, questions and help. "Tricks of the Trade"
lngrng
Re: Cutting thin sheet metal
Post by lngrng »
If you take a piece of plywood or MDF and cut your holes in it with the mill, It will work as your top hold-down, and act as a pattern for your mill to follow…..saves time in the layout, and holds the material tight to the lower table so no slippage, nor will it allow the material to rise when being milled.
