A while back, I bought a (modern) shotgun, in good shape except for a few small dots of red rust, where I presume some water landed before the gun was put away.
The overall finish is pretty good, for a low-priced, mass-produced gun. I'd like to get rid of the rust, which mostly is around where the vent-rib meets the barrel, but without removing any bluing.
Any suggestions ?
Bluing vs Rust
Bluing vs Rust
Pete in NJ
Re: Bluing vs Rust
Start with some fine steel wool and lite oil, be gentle,touch up with one of the out of the bottle products per instructions
Re: Bluing vs Rust
Yup. I kinda thought that would be the advice. Being very lazy, I was hoping for some sort of chemical thing, but considering that at least some bluing is oxidative, I was (rightly) afraid it would take off the blue with the rust.
BTW, on that -- I scored a set of pin-vises the other day, and one or two of them had a little surface rust. I decided they were a small enough investment to try out Evapo-Rust. I had to soak them nearly two days to get rid of the rust, but it worked very well indeed: Pretty much all of it came off -- there are still a few rough spots, and I'll Scotch-Brite them later. But the fingers of the vises, which had a blue coloration, probably from heat-treating, all came clean grey too.
So t'ain't going to go on my gun. I'll do what Hammermill suggested; you can't see the spots from a couple of feet away, anyhow.
Pete in NJ
Re: Bluing vs Rust
There is a product called Evaporust that works very well chemically that dissolves rust and when I used it it did not affect the bluing.
