hi all I am new here and new to machining, I know absolutely nothing I bought a smithy 3 in 1 and now I want to make a mount for my go pro to attach to a pic rail. My question is what bit do I need to mill the part that attaches to the rail? would it be a double 45 or is there another way. I have tried calling the local supplier and he has no idea as to what I want and when I went there he was not there, If someone can tell me the proper name of the bit I need I would be grateful
Thanks
gwhunter
making a mount to attach on a pic rail
Re: making a mount to attach on a pic rail
I'm going to guess you need a dovetail cutter. Go to the MSC web site and google "dovetail cutter". You should find what you need.
Jack.
P.S. We love to know the location of our members, noobees especially, there are times when a nearby member can lend assistance.
Jack.
Possibly a "Double Angle Shank Type" cutter.
http://www.use-enco.com/cgi/INPDFF?PMPA ... PG=INLMK32
I use a double 45 to make the ones I have made but the cutters are usually too thick and I end up with clearance above the rail. It hasn't caused any problems but I don't get a close fit there. I suppose I could grind off the top of the cutter for more clearance.
thanks guys i just order a double 45 I appreciate all the responses
With some creative fixturing you can make a female picatinny mount using just a regular endmill. The internal angles are 90* so just set the work at 45* and you have your internal angle.
Lance Corporal of Marines
