1911 Project
Moderators: JackF, Harold_V
warmstrong1955
Re: 1911 Project
Post by warmstrong1955 »
Keep posting Glenn.
I've been thinking of buying a kit....or at least the parts, to build one.
I only have three 1911's(Combat Commanders count too)....and three can't be enough.
Re: 1911 Project
Post by GlennW »
Didn't do much tonight but hone the bore on a couple of mainspring housings and start on a seer jig.
I find that the key to completion on these projects is to post them. That way I feel obligated and guilty if I don't keep progressing!
warmstrong1955
Re: 1911 Project
Ahhh....I understand!
(Too well)
RSG
Re: 1911 Project
Post by RSG »
Looks great so far Glenn! Looking forward to seeing the rest.....
Re: 1911 Project
I have always said that how one works is a good indicator of the degree of quality that will be achieved. The workmanship being shown here is amazing. Well done, Glenn, although I'm certainly not surprised.
Re: 1911 Project
Post by GlennW »
Thank you for the comments.
Nothing too spectacular last night, just ground a section of heat treated steel bar to .808" diameter to start making a sear grinding fixture.
Re: 1911 Project
Post by GlennW »
Today's contribution was to fit the mainspring housing and did a bit of blending around the grip safety to frame interface.
Re: 1911 Project
Post by GlennW »
Chucked up the ground bar in the lathe and roughed the end down to .115" in preparation for grinding. Then dug out the "Grind All" from the closet and zero'd the bar so the small diameter can be ground to fit in the sear bore (.111") and be dead coaxial with the bar.. Once I get the small stub and the shoulder ground on the bar I'll be nearly ready to grind the unfinished, long, sear nose (EGW sear) to the proper radius. (True radius sear) I know you can buy this stuff, but it wouldn't be as much fun.
Ended up having to work today, so not much time to play.
Looks like I'll probably end up just buying a blank slide and doing the whole deal.
Re: 1911 Project
Post by GlennW »
I finished up my grinding "fixture" and received some parts today, so now I may be able to get going again. (EGW swapped a long sear in there for me rather than the finished sear normally packaged)
The small shank on the rod was ground to fit the sear bore and then ground the shoulder dead square using the "Grind All" and surface grinder. Now the sear just slides on.
Then a 1/8" pin was fit into the end of the bar to drive the sear. Now it's set up on the OD grinder so I can grind the sear between centers. With this setup I could probably grind a hundred of them in an hour, but I only have two to do! Checking the setup, I have .0002" total runout on the bar right next to the sear, so I can live with that. I can also make a simple clamp to secure the sear to the end of the fixture and go back to the "Grind All" and surface grinder to grind a sear if i want to. As it is now, the dead center (spring loaded on grinders) is pressing the sear onto the fixture.
The O.D. grinder swings a 14" wheel, and I have a couple that should do very well finish wise.
Hopefully, I'll have time to grind a sear this weekend
earlgo
Re: 1911 Project
Post by earlgo »
Glen, While you have the sear all lined up and rotating concentrically around the hole, may I suggest a modification that helps get a smooth unvarying trigger pull?
The following is a pic of the unmodified sear, but to make a smooth trigger pull one should grind away the area cross hatched in green to about .005 to .010 below the normal surface. The diameter of the raised boss should be as large as can be fitted on your sear. See blue arrow. This should be done on both sides of the sear. It makes a raised boss on each side so that if there is any slop in the pin hole, the tip of the sear will not drag on the side of the cavity in the frame. See green arrow.
Modified Sear
Modified Sear
I know that since you are honing each hole you will have minimum pin slop, but this modification has proven very effective.
When you get to the hammer, I will post another suggestion, if you don't mind.
--earlgo
Re: 1911 Project
Post by GlennW »
Suggestions are welcomed
Thanks!
Re: 1911 Project
Post by GlennW »
I ended up having to work all day again, but I did get to grind one sear before i went home. Turned out as planned.
