Sharps update
homebrew .357
Sharps update
Post by homebrew .357 » Sun Aug 27, 2017 3:24 am
Hi All, just to let you know all's going good with my home made Sharps rifle, a lot of lead has gone down the barrel now and just had to make the front sight a bit higher as it was shooting 2/3". It`s now spot on at 50m 8 shots in a 60mm wide group. Pic`s, sorry no go with IMG OR URL ?. Homebrew.357.
JackF
Re: Sharps update
Post by JackF » Mon Aug 28, 2017 11:57 am
Homebrew, thanks for the update.
Jack.
LVRR2095
Re: Sharps update
Post by LVRR2095 » Mon Aug 28, 2017 2:37 pm
What model Sharps did you recreate?
Keith
Re: Sharps update
Post by Harold_V » Mon Aug 28, 2017 3:21 pm
LVRR2095 wrote:What model Sharps did you recreate?
Keith
Don't know if he provided that information in his ongoing posts about the build, but it's a wonderful read, displaying some amazing talent. Here's a link to the thread if you're interested.
https://www.chaski.org/homemachinist/vi ... hp?t=99914
TRX
Re: Sharps update
Post by TRX » Mon Aug 28, 2017 6:09 pm
So, what's the next project?
homebrew .357
Re: Sharps update
Post by homebrew .357 » Thu Aug 31, 2017 4:15 am
As I have all my gun drilling bits I`m drilling and rifling a few blank .45 cal muzzle loading barrels and will cut rifle them with a 1-48 twist as I have changed to a sine bar on my lathe and can now get a twist from 1-18" to 1-70", and will put them on our trade me to see if someone wants to make a rifle. Cheers, Homebrew.357.
homebrew .357
Re: Sharps update
Post by homebrew .357 » Fri May 11, 2018 2:22 am
Hi all, with my new drilling and rifling set up I thought a .50" cal swap barrel for my Hawken .45 would be the go. Now I could cut rifle with a twist of 1-18" to 1-70" and Right hand, From Ebay I got a .50" gundrill so away I went, drilled hole came out, .501" to .499". A good lapping to smooth and true the bore then made up a new rifling cutter head for a .50 bore, I cut eight groves with a 1-48' twist about .010" deep and again a lead lapping with diamond past. Progress pics. Homebrew.357. PS, Have found how to load pic`s!!.
, the Hawken .45.
,The new sine bar setup.
, Cutting eight grove rifling.
, the finished barrel, not to bad.
JackF
Re: Sharps update
Post by JackF » Fri May 11, 2018 9:32 am
Nice job. :D Did the lapping reduce the .002 bore dia. difference any? How does it shoot?
Jack.
homebrew .357
Re: Sharps update
Post by homebrew .357 » Sat May 12, 2018 1:44 am
Now hang on, don`t jump the gun, as you can see it`s got no sights on yet and it`s still round. So set it up in the lathe to shave the barrel octagonal and being 1" stock, the same as my .45 barrel, when it was finished it fitted in the stock nicely . Now next job was milling and fitting the sights, lined them up to the bore centre , hopefully on target. pic`s, Homebrew.357.
homebrew .357
Re: Sharps update
Post by homebrew .357 » Sun May 13, 2018 2:54 am
You can see I've made a booboo here, but I was looking at my Sharps up date and thought I would put a new post about my .50 barrel build but forgot to get of this one. Anyway the back sight was fitted, it was a two leaf flip up sight I had in my bits box, save me making one, so when I was on my hunting trip I gave it a proof test, 90gr 2f , 490 p r ball and all was good. Fast forward went to the range to check the sights at 50mt with 65gr 2f and p r b, first shots where 7 1/2" low and with the 100yrd leaf sight up the last two shots were just under the red patch, my aiming point for all the 11 shots. All in line horizontally but I worked out I need .032" off the top of the fore sight. Still rubbing my sore shoulder, the big bore sure has a good smack to it. Pic`s of things, Homebrew.357.
, Back leaf sight on.
, The target proof.
,The rifling rod setup for cutting the rifling.
homebrew .357
Re: Sharps update
Post by homebrew .357 » Thu Jun 21, 2018 1:54 am
Jackf, the lapping only gets rid of the sharp edges and smooths things out, not much meatal is removed. Still trying to get it shooting to the sights, at 50m it`s still a bit low so will keep cutting down the front sight till its on. Showing good grouping at 50m with 50gr 3f and with a bit more shooting and polishing the bore should come right, not bad for a home made barrel. Homebrew.357. range pic.
homebrew .357
Re: Sharps update
Post by homebrew .357 » Fri Jul 13, 2018 2:14 am
And getting back to the Quigley Sharps in 45-70 here she is in full roar at the range.
